Briggs 17.5 PROPER valve Adjustment method Debate
Tinkerer200
If you understand what you're doing, you don't have to follow any rote memory procedure.
http://wallaceracing.com/cambasics.htm
That is the point. You have no idea if the person you are talking to knows what he is doing or not. Right now there is a thread on another forum where the fellow says his engine cranks but it won't turn over.. I have seen many similar statements over the years and quit responding to them.
Walt Conner
PTmowerMech
Walt Conner
HA, I seen that. Termanology is a tricky thing sometimes.
Scrubcadet10
Moderator
Staff member
To me crank and turnover are the same.
"It'll crank but won't fire"
" It'll turnover but won't fire"
PTmowerMech
I'll have to remember that. Turnover is just that. Crank, to me, means to start and run. But I can see what you're talking about. I've heard people say they "cranked and cranked and it just wouldn't start."
Crank comes from the pre starter motor era when you had to crank your engines with a crank handle to start them
So crank = turn over = spin
Fire = just that, fires once or twice but does not start
Start = runs for a few seconds or more but not necessarily all the time
Runs = you can mow
Runs = you can mow
My favorite is runs but won't start.
Tinkerer200
Runs = you can mow
Yes, Above, "Crank, to me, means to start and run." No.
Walt Conner
