SteveHaller
- Oct 3, 2017
- 6
- 12
I have a Hustler Sport zero turn lawn tractor with a 17.5 HP Briggs & Stratton OHV Intek engine - model #31G777-3304-G5. The unit is about 5 years old, very well maintained and has seen moderate residential use.
For about 6-8 weeks now, I have been struggling to diagnose what I would call a stumbling or mis-firing only in and around half throttle in terms of engine RPM. At idle it runs just fine, and at near to full throttle it runs fine as well.
See the video/audio at this link to hear exactly what it is doing as the throttle is adjusted. This is without the PTO / blades engaged, but it does the same thing when the blades are engaged, and it results in a noticable vibration in the unit given the engine stumble, which again will go away if I take up to near full or full throttle.
[video]https://photos.app.goo.gl/4DbZuIEudtoNh7dS2 [/video]
I installed a new platinum plug, new air filter and new fuel filter this spring as part of routine maintenance. I was originally thinking it may be a fuel starvation problem, especially since the fuel filter housing is translucent and I can see that it is not full of fuel and has air in the top. To troubleshoot this, I ran it for a few weeks with the fuel filter removed from the system and I ultimately saw the same stumbling. Also, the fact that the problem goes away when I throttle up to full, would seem to suggest it is not a fuel issue -- unless it is possible that the fuel pump is not delivering enough fuel for some reason at that mid-range RPM, but does at high RPM.
There is also a fuel system vent tube on this unit, with a small foam air filter, and I have also cleaned that to ensure there is no blockage -- no improvement.
Any thoughts or advise on this one. Could this be an ignition issue that only appears at this RMP range / throttle position? I am struggling with what to look at next.
Thanks in advance for any help or suggestions.
