Briggs 137202 carb hole not tapped
snapz007
Replacing the carb on my B/S 137202 (tiller), and I've run into an issue. At the back end of the carburetor, there's a small hole - the mounting hole for the idle spring bracket (see photo). On the old carb, that hole was tapped for a small screw. On the replacement carb (actually, two replacement carbs so far), that hole has not been tapped at all (as far as I can tell). Am I good to just go after that hole with a tap and cut it to fit the existing fastener, or is there some other way I should be handling this? (Preferably short of rejecting a SECOND carburetor, shipping it back, and hunting a THIRD source for the blasted thing.)
Photos:
Old carburetor - idle spring bracket screw circled in red
Replacement carb - untapped hole circled in red
the proper way would be to buy the correct tap and tap the hole... however (some fruit may get thrown at me here), i replaced the engine on my personal pushmower with a short block a few years ago and the small holes the intake manifold screws went in were not tapped... so i got a can of WD-40 and the manifold screws, and slowly cut the threads into the block with the manifold screws. started with my hand nut driver, then choked up on my handle of my 1/4 drive ratchet . used it just like a tap, back and forth, back and forth, spray some. slow and steady won the race. WD40 was used liberally.
Tap away to your hearts content
Carbs are designed to fit dozens of different applications but to cut cost, holes are only tapped where necessary
If I remember right, the screws are a self tapping type with a tapered end. You just have to be careful not to break it off.
Thanks for the help, all. Idle spring bracket mounted. Now I just have to go get a new fastener for the throttle linkage - it's cut for the wrong size, the bolt from the old carb is NFT........ and my tap set only has coarse-thread taps. Sighhhhhhhh. All told, this $15 carburetor's only gonna end up costing me about $300 in lost time. LOL
Chinese carb alert, again. Sometimes saving money is not saving money.
