I have a Dixon Zeter with the B&S 11.5 IC engine. I was mowing and it acted like I pushed the throttle as low as it would go, which I didn稚. It then stopped running. I got it restarted but it would only idle, then it eventually stopped. I changed the fuel filter, spark plug and went ahead and changed the oil. Now it will not start. I have spark. It did not smoke during any of this. Any suggestions? Let me know if you need more info!!
Thanks
Chad
Thanks
Chad
