Breather problem
Tommy, there should be either a metal tag attached to the blower housing that says Model, type, code. Or they may be stamped into one of the valve covers.
Should says something like model type code
35xxxx xxxx xx 11xxxxxx
OK, I will take another look . Thanks, Tommy
I hate to be pain, but just confirming to make sure the manual isn't wrong in your case, and could fix a problem along the way.
