If you are oiling a foam pre-filter, put some oil on a paper towel and wipe onto the filter surface. If it seems as if none is visible on the foam you done it just right. Or throw the dam thing in the trash and that's right too.
This information is coming from a member that had a difficult time deciphering what the original oil on a filter was all about.
OK sorry , I misunderstood. I have the model # from the engine tag written down at home. I will post later today. Heck maybe I am running the wrong one? Thanks, Tommytommy the reason I asked for your model number is because there are 41 engines in the 35xxxx range that use the 692519 filter. And sometimes there are errors in the owners manual, and sometimes briggs will change something like the part number for the air cleaner because of a problem.
