Mower King
- Sep 19, 2018
- 663
Believe it or not.....mowers start easier and RUN BETTER on 87 octane fuel.........and NOT high octane fuel !
All newer mowers are good for up to 15% of good, fresh ethanol gas, says so right on the fuel caps ...it also depends on where and how the mower is stored.But where do you find Ethanol-free 87 octane fuel? Locally they only sell Ethanol-free in 90 octane. I'll deal with the 90 octane instead of ethanol damage.
I typed that wrong...it's 10% not 15%.....my bad!All newer mowers are good for up to 15% of good, fresh ethanol gas, says so right on the fuel caps ...it also depends on where and how the mower is stored.
That's all true but......I call that, "job security"Have you guys seen a mower carb that looks like someone poured sulfuric acid inside it? On these used mowers I get, you can tell if they ran E10 or not. I cringe when I get a new to me used rider and open the carb up. Praying heavily for no E10. These rider carbs get pretty pricey compared to a push mower. I've had some carbs where you couldn't even get the main jets out and the float pin area was all eaten up from corrosion/water/E10. I exaggerate a LOT but that sulfuric acid comment was no joke.
So, I bought a HRX217 with the Easy Start auto-choke less than a month ago. I've used it 4 times- every time it has taken AT LEAST 2 pulls to get it started. Today it took 4. I always thought Hondas were one pull from cold start. I see nothing in the manual about having to pull multiple times. Is it common in the HRX with auto choke to have to pull multiple times to get it going? It starts back up on the first pull after the engine is warm. Does the choke just need to get "broken in" from a few uses to get it to start up on the first pull when cold?
Just trying to figure out if this is normal behavior. Kinda disappointed a $600.00 push mower isn't starting up on the first try.
Thanks in advance
I have the same issue each fall and spring when it is colder and when in low 40's needed to use starting fluid. The solution is easy. Very slowly pull the rope all the way out two or three times. This appears to manually prime the carburetor. Then pull hard as you normally would it mine always starts on the first hard pull!!!!So, I bought a HRX217 with the Easy Start auto-choke less than a month ago. I've used it 4 times- every time it has taken AT LEAST 2 pulls to get it started. Today it took 4. I always thought Hondas were one pull from cold start. I see nothing in the manual about having to pull multiple times. Is it common in the HRX with auto choke to have to pull multiple times to get it going? It starts back up on the first pull after the engine is warm. Does the choke just need to get "broken in" from a few uses to get it to start up on the first pull when cold?
Thanks in advance
