lawn mower fanatic
- Jun 8, 2012
- 6,749
Relative has one that's not used and the self-propel bar (the black bar) has no tension. Wish it was an easy fix.
Your drive problem is more than one of three things. Sloppy worn wheel bushing, not allowing the gears to stay engaged. Bad drive gear, it should be flat, with no concave wear. Bad key or engagement washer, not allowing the key to pivot properly.
exotion,just seen them on ebay or amazon for 10.00 each
Forgot to add that when you install the gear back on the shaft it must be in the same direction as when you removed it. Will not work at all if installed wrong.
