BWH,are you talking about the hydro fluid or the little gearbox that the deckshaft goes into that's located under the deck?I use OEM hydro fluid but as to that gearbox under the deck the dealer said regular 90wt gear lube will suffice.I did get a qt. of Purple something[?]now I'm going to have to research this futher before I do this.I'm going to Grasshopper"s web site to see if I can find any info....russ
