bobcat Z219 electrical problem
TLBud
My bobcat z219 has been flawless until, I was seated and shut it off to talk to neighbor. I never got out of the seat and went to mow I started it and when I released the brake it shut off the mower.. I checked the seat switch with a multi meter and it works fine. what do I look for now.
Blades still on?
Remove the ignition coil kill wire. Should run the tank dry. If it does you have some safety switch or wiring issue.
