bobcat Z219 electrical problem
TLBud
My bobcat z219 has been flawless until, I was seated and shut it off to talk to neighbor. I never got out of the seat and went to mow I started it and when I released the brake it shut off the mower.. I checked the seat switch with a multi meter and it works fine. what do I look for now.
Blades still on?
Remove the ignition coil kill wire. Should run the tank dry. If it does you have some safety switch or wiring issue.
TLBud
found problem, clutch switch is bad. BTW, blades wasn't turning.
