Blown engine... are these models interchangeable?
Team_Dub
Craftsman LT1500 Model 247.288811 with a VERY blown 31C707-3346-G2/G6.
Had oil. No idea what happened, except that it was sudden and catastrophic. First cut after Craigslist (robbery) purchase. Can't push mow due to physical issues.
My question is will a 31R907-0007-G1 be a suitable replacement? Same crank size and keyway? Been looking but can't find the answer.
Thanks in advance.
Boobala
Team_Dub
To me it looks like a straight-up engine CHANGE .. everything points to being a simple R&R procedure, possibly a difference in engine wires but that's an easy fix, if the R model is a good motor I'd go for it ...... keep us updated and ask for help if needed ....... :thumbsup:
Thanks a ton,Boobala - that's what I was thinking and hoping to hear!
:thumbsup:
Team Dub if your crank and the replacement engine has the same exact measurments then you are good to go.....
I haven't looked at your specs, but the type codes are meant for color and stickers for different mowers by different brand names.... Mostly........
Crank size is your major concern Mon Ami ~!~!
Let us know ~!~!.............
Team_Dub
Boudreaux - I was hoping an expert here would know that info and pass it along.
Still looking...
Thanks!
Team_Dub
This is from the proposed replacement:
1-Inch by 3-5/32-Inch Length Crankshaft Tapped 7-16-20-Inch
That's the most common length.... Now if your old one has that length which I would bet good money it does, then you are golden.......
Plus Tard Mon Ami ~!~!
Check the plugs on the ends of the alternator.
Briggs use different colours and configurations for different capacity alternators.
If they care different ( one of the code things ) you can swap them over, just adds a little more time.
Team_Dub
Thanks for all the info!
It's ordered and will be here Tuesday.
As long as the crank is the same, all I *should* have to do is swap over the old front exhaust and possibly a little electrical tweaking.
I'm sure issues will arise and I will keep you posted!
:smile:
Team I thought you had a spare engine off of a used mower at your finger tips.......... I didn't know you ordered one.....
I wish I would have known..... I could have got you a better price and the same engine for your mower.........
