Hi
John Deere L110 .. older model.
Last year near the end of the season my blades would not engage at all. I checked the belt and it was loose. I figured I needed to change the belt. I bought a new one (John Deere 42") belt that was specified for this model.
I Changed the belt. It still seems a little loose ... Now if the the higher the mower height the faster the blades turn. They will turn barely at the lowest settings and turn really well at the highest setting but do not turn fast enough at the cutting heights between 2.5 and 3.5
The PTO cable tension setting is already at the max location.
The belt is on as per the diagrams in the operators manual and the new belt instructions.
