Blades disengage
Big Ranj
Today while mowing the blades would disengage for no apparent reason and then re-engage with no actions taken by me. Belts appear to be in tact. Any suggestions?
KennyV
Also check your Wiring.... pay particular attention to the connectors At the clutch... And the Ground at the clutch... :smile:KennyV
banshee350
I had the same problem with my 321d. It turns out it was the seat safety switch. You can unplug it then run a jumper to connect the 2 wires and see if it still cuts out. It dosn't cost anything to try, but if it is the problem make sure you replace the seat switch and hook it back up.
Big Ranj
Update - the issue was the wiring connection at the clutch. Thanks for steering me in the right direction!
ddl1170
ssssssssssss
