bobthewoodbutcher
- Aug 22, 2014
- 13
- 44
In addition to the 2 bolts and nuts that hold the blade on there are 2 other nuts and bolts outboard that i cannot find any reference to..
The blade holder is tapped to accept the bolts and the nuts are used to jam against the blade holder essentially providing a lock nut.
I appears that the only function is might be to make sure the blade is the same height on each end
