blade mounting RER
In addition to the 2 bolts and nuts that hold the blade on there are 2 other nuts and bolts outboard that i cannot find any reference to..
The blade holder is tapped to accept the bolts and the nuts are used to jam against the blade holder essentially providing a lock nut.
I appears that the only function is might be to make sure the blade is the same height on each end
Model number. I have never see that. I also have not worked on one in over 20 years.
Looked up parts and they are just called nut and bolt. Still have no idea.
They are a "fine-tuning" adjustment to get the blade tips even. It theory it probably works, but in reality, not so much.
