Murray Part: 094047E701 & 094049E791. (Right and left).
The brake pad is attached to an arm with 2 screws and glue. The 2 screws alone don't hold the pad securely and it wears out fast [original lasted 16 years). I am using brake pad material as replacement (2 year life span), not sure if Murray used something special.
