blade brake glue
biller
Murray 425001x8E. Blade brake arms (pad assembly) are no longer available. What type of glue would hold brake material on existing arms?
sgkent
what is the part number or photo of it etc
biller
Murray Part: 094047E701 & 094049E791. (Right and left).
The brake pad is attached to an arm with 2 screws and glue. The 2 screws alone don't hold the pad securely and it wears out fast [original lasted 16 years). I am using brake pad material as replacement (2 year life span), not sure if Murray used something special.
biller
Can't figure out how to get picture on here. Sorry.
I suggest you take the brake material and arm to a good body shop. They will have the best glue available for jobs like this.
Hammermechanicman
Many years ago NAPA sold a tape that you baked in the oven at 400 degrees to bond clutch and brake linings. Doubt if they still sell it. There are a bunch of paint on adhesives out there.
biller
