Well....... actually if you have blades with a single center bolt with nothing to hold it like a star or a couple bolts in the adapter the blades tend to self tighten and if the customer hits a root or something solid it can tighten the bolt to SOB levels. Just engaging the blades at full throttle can tighten blades. Had a commercial customer who changed blades every day and he could put the blade bolts in just past finger tight and after he engaged the blades at full throttle a couple times he needs a wrench to get them off.Blade bolts do not self tighten. If you have difficulty you are tightening them too tight to begin with and fail to clean and lubricate the threads. A simple box end or 8" ratchet will tighten them sufficiently. Small couplers do not lower the Pressure, they lower the Volume.
