I don't change blades often, but I have had a problem getting the nuts loose even with a 600 FTLB impact wrench. I installed a flat washer under each nut and I haven't had the problem since. However I do have to replace the flat washers periodically. The cordless impact tool will have an unknown torque output and the state of charge and battery condition will affect the torque output. I don't recommend using anti-seize on the nut as this can easily promote an over torque condition. I'm not sure why you change blades daily, but I have no idea what type of mowing conditions that you have to deal with. At the end of your work week you must have one large pile of blades to sharpen!!!:confused2:
