MBDiagMan
- Aug 28, 2013
- Threads
- 7
- 140
I have an idea how to make a brand specific blade balancer. I have a Grasshopper and someone gave me an old grasshopper deck to wreck out. Among the spindles from it, there are several good smooth bearings. I plan on cleaning everything and put a spindle together with light oil in the bearings rather than stiff grease. I will then mount it on the wall with the shaft horizontal.
I will tap out the blade mount hole and make a wing bolt, running a die over the bolt, so that it will thread a little more easily. Once done, I expect to be able to wing bolt the blade onto the spindle shaft and use it the same as how the magnamatic works.
The blade hole on the grasshopper is smaller than the blade hole on my Bad Boy, so I will find or make a bushing to fit those blades on it as well.
If this works out, I will also fashion a rod to check straightness as done with the magnamatic.
If it works well, I will post some pictures.
Wish me luck,
Larry
Wish me luck,
Larry
