I can't seem to find ANYTHING online about how to remove the wheel. There's no nut, so obviously the clip has to come off. How do I do that without breaking the clip or the wheel? Are replacement clips available at say, Home Depot?
I need to fix the hieght adjuster. It looks like it's a just bent enough that it won't fully grab the notched plate, and it looks like I could use pliers and squeeze it closed a bit and it would be all good. But to get to it, I have to take off the rear wheel. It's the newer 19" model, and it's NOT self propelled. Would be so much easier if it were just a nut!
I read one small post that seemed to suggest using the claw end of a hammer. Sounds like it will break things...
-Sean
-Sean
