How cheap would you cut 30 acres of grass? It will be cut every two weeks till Fall?
$35 an acre
things to figure in..........do you have to move equipment or is it 30 joined acres......how rough is the ground.........how low do they want it cut......any weedeating....how many mowers will you be using
