Bidding on acreage
jekjr
How cheap would you cut 30 acres of grass? It will be cut every two weeks till Fall?
exotion
Nope. I would leave it for someone else. Lol but that's me I don't have the man power for that
Carscw
Say you can mow 2 acres a hour with one mower. Use two and it will take 6 to 7 hours.
I would charge $500 to $600
My toro will cut 3 to 4 acres a hour so price would drop if I had two
$350 to $400
TaskForceLawnCare
$35 an acre
BHLC has a great base figure. I'm assuming its something commercial and mostly wide open. If your string trimming and doing a bid. Ask to walk the property and imagine you string trimming while timing the time it takes to walk it and figure in anywhere from $1.50 a minute up to whatever you think you need. Then place you bi weekly now based on that
edd
things to figure in..........do you have to move equipment or is it 30 joined acres......how rough is the ground.........how low do they want it cut......any weedeating....how many mowers will you be using
jekjr
We cut it Monday and Tuesday. Won't be cutting it again unless they agree to a good bit more than we cut it for this time. According to Planimeter it is actually 39.4 acres. Really rough. Many, many, many, trees. About 2 hours of weed eating.
