Best time of year to grow grass
dria
I am wondering if there is a best time of year to grow grass. I have had some good an bad experiences growing grasses. Is it better to do this in the spring, summer or fall. Does it make a difference?
KennyV
My grass will grow all spring and summer AND fall...:biggrin::biggrin:
But I think you are referring to the best time to plant grass...
Generally the fall is going to be the best time to start grass seed... but if you have an automatic irrigation system the spring will work OK... :smile:KennyV
rekees
September is the best month to start grass.
Ross
Yes, in the fall is the best time. Make sure the seed fertilizer and food are all compatible, and are conducive to the winter season. Are you planting bluegrass?
RobertBrown
Depends on the type of grass you are planting and how much sun you have and wether or not your are overseeding or starting with dirt. I would plant on level ground when you get the most rain and follow the manufacturers instructions.
I would not use pennington seed!
KennyV
dria
:laughing: Haha, very funny! Yes I meant plant grass! Looks like I had better get on the move on then! Thank you all for the great advice and replies.
