Hi. I'm a newbie from NE Michigan.
I have a Husqvarna MZ5225 ZT mower and am planning to install a tach. Reason is, I need to figure out the optimum RPM for best tip speed of the blades. I'm not a commercial mower, but I have a lot to mow and I've learned that keeping the blades sharp and RPMs up will give the best performance and efficiency. I use full synthetic oil.
Once I install the tach, can anyone tell me what RPM I should be running with a formula to determine my blade tip speeds so that I'm not just guessing?
There must be one of you techies out there who would like to tackle this one.
Thanks in advance
Deke
Thanks in advance
Deke
