Bent push rod
IanG
I have a Honda HRC216, it will not start. The compression is very low so i took the valve cover off and found an issue. I am trying to find out what is going on. Any advice would be helpful.
shiftsuper175607
Adjustment became loose...push rod slipped out of place and became bent in the process.
Hopefully nothing else was damaged.
Get a new push rod, install and adjust valve per specs.
reynoldston
After looking at this post, very good advice I would have to give you the same answer :thumbsup:
IanG
So I got a straight rode and started to replace the bent. I found another problem, seems the top valve is stuck in place and doesn't move. Any idea what could cause this? Or if I am doing something wrong? Thanks
reynoldston
I guess you are saying the valve wouldn't move is the reason the push rod bent? It sure looks like head removal time to find the problem.
IanG
I have never dissassembled an engine to that point. I guess u gotta start sometime
reynoldston
I would suggest if you are going to do it yourself and never did any thing like this. Start with a service manual, even if you have to buy one. Most service manual will give you a step by step information. Also if you don't own one get a torque wrench, you can pick up a cheap one from HF. Just take your time and follow the service manual and you should be OK. Who even knows you might enjoy it so much you might get into the mower repair business :thumbsup:
shiftsuper175607
Which valve had the bent rod? Was it the top one?
If it is the one that had the bent rod...it will not move because the push rod moves it.
It doesn't have a push rod until you put one back in.
Take out spark plug and find top dead center
Put the push rod in...use a flashlight to be sure it is hitting the tappet concave in the bottom. Put the other end of the push rod under the rocker arm
Tighten the nut to set the correct clearance...use the lock screw/nut whatever it has to lock it in place.
recheck and redo until correct.
I bet there is a Youtube video showing how to do it.
The compression could be low if the push rod knocked a hole in the top of the piston. look in the spark plug hole with your flash light...maybe you can see.
IanG
The top valve doesn't move, with a new push rod or without.
