Belts on ariens ikon x
Avondebbie
I am having trouble with belts. Drive belt had to be replaced at 6 months. It broke. Now after that was fixed the mowing belt keeps coming off. Anyone else have belt problems? Mower isn’t even a year old yet
Once a belt has popped off a couple of times it has sufferred internal damage & should be replaced .
You have o work out why it happened.
Usually it is because of debris stuck around blades or pulleys , a badly tensioned belt or misuse.
