PTmowerMech
- Apr 16, 2018
- 442
- 3,412
I keep my mower very clean and housed in a garden shed. My pride and joy as such.
I've checked all the springs I can see , my concern is a spring has disappeared ie broken and therefore I wouldn't pick it up as I'm not familiar with every spring and where it should go. My model number is 13c2775s000, 2018 MTD 420cc powermore, 7 speed.
I did jave to move the tensioner arm to get the old tensioner pulley off to replace it...could it be I didn't put it back in the position is should be ? The tensioner spring is in good condition and replaced as I found it.
I had to tilt the mower slightly to get under and get the front pulley nut loose. Could this have upset something ?
I've followed the gear rod it rattles , should it ?
Is there usually a spring from the rod to somewhere ? Sorry if I'm a little vague, this is all new to me and without a manual of the underbelly and layout, parts etc, it's really difficult.
Your main drive belt has no tensioner? According to the Partstree diagram, it's a straight shot to the engine. So just to be sure, the belt is secure around the engine pulley?
Also, the transmission linkage from the pedal is correct?
Or am I looking at the wrong diagram?
