Battery Replacement
jpalladino
Yesterday I purchased a new battery for my Z425B mower. It has 350cca vs. the 280cca old battery that was replaced. The physical size is the same. Will the additional cca create any electrical issues? I should have thought about this before the purchase and I should have joined this forum a long time ago. Thanks for any replies.
No problems as long as the voltage is the same
Sent from my iPad using LMF
The 350 is a better battery. It will spin the engine over faster.
(( racing is the only sport that you need two balls ))
Buy purchasing the bigger cold cranking amps battery, you will not have any electrical issues caused buy the battery.
Its simply going to allow the motor to turn faster. As long as its the same dimensions as the old one.
just make sure your connections are the same side as that may be the only issue. Having a cable not long enough.
