Battery quit charging...
Riverman
My Craftsman 17 hp Kohler riding mower quit charging the battery. I replaced the battery because it was old, but I still only get 12.6 volts at the new battery when the engine is running or when it is turned off. Can someone please tell me how to test the charging system? Thanks
reynoldston
You should be getting 28 AC volts to the rectifier and from there close to 14 DC volts to the battery at wide open throttle.
Riverman
CV490S engine... thanks for the manual, it tells exactly how to test the charging system.
Riverman
Looks like the stator is bad... anything I can do except buy a new one? Thanks
Sorry, if it tests bad, time to replace.
