JDZ930M Forum Newbie Joined May 29, 2022 Messages 1 May 29, 2022 #1 My John Deere Z930M battery is not charging. Had the battery tested and charged and was told it was good. Lasted about 6 hours of mowing and died again
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,527 Location Pluto May 29, 2022 #2 Sounds like the voltage regulator has failed.
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Messages 24,995 May 29, 2022 #3 Or the wire from the rectifier back to the battery has failed
S smileyblue Forum Newbie Joined Jun 27, 2014 Messages 4 Jun 12, 2022 #4 StarTech said: Sounds like the voltage regulator has failed. Click to expand... Replaced it. Checking the wires now
S smileyblue Forum Newbie Joined Jun 27, 2014 Messages 4 Jun 12, 2022 #5 bertsmobile1 said: Or the wire from the rectifier back to the battery has failed Click to expand... You were right , thanks!
