I had the same problem....I thought I had a battery malfunction sometimes the engine would spin for a while if I jumped the battery.Then click click click..... This was a false result of jumping the engine, actually the engine valves would move enough sometimes to let off built up pressure so the engine would spin then the valves would get "stuck again and the flywheel would not spin....click click....I finally figured it out when I removed the spark plug then turned the start key. The flywheel would spin without a problem. My valves were way out of adjustment!!!!!! Please let me know if your engine is now running and what fixed it or notify me when you have found your problem. I also inspected the starter brushes and was amazed they were still in good shape as is the solenoid. I have burned out a new battery.
Dennis
Dennis
Craftsman 4500. 24 hp Vtwin. 42" deck. 7 years old. About 380 hours. I change oil, filters, spark plugs, etc every year. Last year had Sears come change deck belt and 1 bad spindle. Buy new battery every spring.
Bought new battery end of March. Mower started off battery. Did not mow in April because no rain meant no grass. Finally went to mow 2 weeks ago and would not start off battery. Started off jumper and ran fine for an hour. Turned off. Attached spreader. Would not turn on off battery. Started off jumper. Spread. Back into shed.
Last week I hooked the battery up to charger so it would be ready for weekend. Weekend comes, time to mow again. Voltage meter said 12.9 volts. Put battery in mower, will not start off battery. Remove battery and go to store where I bought it. They say battery holds charge fine. Go home. Top off battery with charger for an hour. Back into tractor. No good off battery. Starts fine off jumper.
So do I need a new starter motor? Check for bad wiring? Check for winter debris under the engine housing?
Or maybe just bite the bullet and buy another battery and keep this one charged between uses?
Much thanks for any suggestions.
