Craftsman 4500. 24 hp Vtwin. 42" deck. 7 years old. About 380 hours. I change oil, filters, spark plugs, etc every year. Last year had Sears come change deck belt and 1 bad spindle. Buy new battery every spring.
Bought new battery end of March. Mower started off battery. Did not mow in April because no rain meant no grass. Finally went to mow 2 weeks ago and would not start off battery. Started off jumper and ran fine for an hour. Turned off. Attached spreader. Would not turn on off battery. Started off jumper. Spread. Back into shed.
Last week I hooked the battery up to charger so it would be ready for weekend. Weekend comes, time to mow again. Voltage meter said 12.9 volts. Put battery in mower, will not start off battery. Remove battery and go to store where I bought it. They say battery holds charge fine. Go home. Top off battery with charger for an hour. Back into tractor. No good off battery. Starts fine off jumper.
So do I need a new starter motor? Check for bad wiring? Check for winter debris under the engine housing?
Or maybe just bite the bullet and buy another battery and keep this one charged between uses?
Much thanks for any suggestions.
