Battery drain while operating
Lighting is completely independent of the battery.
Kparent
Results of test:
battery just off the charger, engine at rest: 14v
start engine:14v
two minutes later:14v
manually engage mower:14v
I tried to think if there was something different between the circumstances of this test and when I mow. i realized that during the test the key was in the mowing position. When I mow I have to start out backing the mower out of its stall. I leave the key in the reverse position. So while the engine was running with the mower engaged I moved the key to reverse, the voltage dropped to zero.
ps: after about fifteen minutes of running the engine with key set to mow, shut it off then it restarted without hesitation.
Kparent
I replaced the ignition switch.
tested voltage while running with mower engaged, key on mow:14v
moved key to reverse: 14v!
every time I restart it now it starts right up.
perhaps it’s fixed?
