J jeff Well-Known Member Joined May 8, 2010 Messages 151 Aug 27, 2010 #1 Snapper single cylinder lawn tractor. Every time the pto is used for more than a few moments, the battery will not restart the mower. Voltage regulator shows 14.7 vdc output. Why is this draining the NEW battery?
K KennyV Lawn Pro Joined May 5, 2010 Messages 5,447 Aug 28, 2010 #2 jeff said: Voltage regulator shows 14.7 vdc output. Click to expand... Is this what it measures with the PTO on? Is there any AC measurable at the battery with the engine running?
D Dannie Member Joined May 7, 2010 Messages 22 Aug 28, 2010 #3 Check the PTO it may be bad.Had same thing and had to replace PTO.
