Shackelchevy77
- Dec 10, 2011
- 2
- 18
Before you decide that a coil is bad two problems i have noticed. Watch the way you tighten the bolts one will pull the coil away from the flywheel and the other will push it closer take your time and watch what happens. And second clean the magnents and and the coil it will revive a "dead coil".
