geekpipe
HI.. hoping i can get some insight into this magnum mz 2013 zero turn i picked up cheap. Sure appreciate any help with probably silly questions. First zero turn.
1. we used it to pull a small bushhog DR unit behind it. Didnt use blades on BB Magnum. After about 2 hours.. i tried to engage the Magnums blades and it kept stalling out immediately. Throttle all the way up. Has new plugs and air filter but not new fuel filter.
2. the grass where i was .. more of grass and rough ground but totally dry. back wheels kept spinning. i assume its due to the ground as its not regular smooth lawn.
3. when i push sticks forward or back there is like a straining sound or groaning. almost like in a car when power steering groans. Any idea how to fix this?
4. sticks are way too sensitive and too close to me.. any way to make them less sensitive or move them a bit forward?
thanks!
thanks!
