B8200 HSD face lift an tummy tuck
coming right along :thumbsup:
This will be a great restoration:wink:
:smile:KennyV
Restoration did you say restoration.:laughing: There is no way that my bumbling attempts on this tractor can resonably be called a restoration. But I do thank you for the kind comment Kenny. :biggrin:I finished the hood and painted it. Oooooooy, a body man I am not. Orange it is.:smile: Dusty
I got some more done.
Tin work is done other than making a new grill and painting the dash. These will get done if I get time. Tomorrow I will clean up and pull the tractor in and pull the plugs on the trani and rear dif and let them drain while I look at the valves and a couple of other things. :biggrin: Dusty
It's gettin' pretty Orange in there...:thumbsup:
Are you going to put new decals on it?... :smile:KennyV
I haven't made my mind up yet Kenny. Not on my priority list yet. The rain we are getting tonight could be snow tomorrow. Anyway I did some cleaning and put the Kubota in the shop. Drained the tranni fluid. It had dextron in it. Almost 5 gallons of it. Wasn't expecting that much. Had to change pans in a hurry. Changed hydraulic filter and pulled the screen. The screen had a wee bit of metal on it but not much The diff lock rod was rubbing against the steel hydro line and wore a groove in it. Not happy about that. And then my stool broke.:thumbdown::biggrin: Dusty
OK I re and re d the mid pto with a new seal. Next I am going to tackle the leak in the trani housing. Sorry no pics tonight.:biggrin: Dusty
Moving right on... Did you weld up your stool???
Did the PTO shaft seal repair have any particular problems?
:smile:KennyV
I'd put a nice coat of Kubota orange on that stool and call it done. Love the pics of the tractor. Kubota's are awesome machines. Please keep the pics coming.
Hi Guys, No real problems with the mid pto, but I did not get gaskets. So I used Permatex gasket maker. I hope it works ok. I cleaned off the patch on the trani with a wire brush then cleaned it of with acetone. Then I used a brush and covered it with fibreglass resin. Then I drained the cooling system and replaced a drain hose between the rad and the block. These are great little tractors and easy to work on. I haven't fixed the stool yet but I will. Some pics
