- Feb 19, 2020
- 123
- 12,912
Cracked/broken cylinder ring. But need good check on intake to that cylinder.Trying to help my neighbor. John Deere L120A B&S 20hp twin,406777 0139 E1. Has some popping and loss of power. Checked with infra red thermometer and the right side exhaust is about 100 degrees cooler than the left. 1. swapped plugs, no change. 2. checked compression, both around 140. 3. Checked valve lash on both, all set correctly. 4. Checked valve travel, both exhausts were same and both intakes were the same. 5. Will run on each cylinder by itself. 6. Checked diodes in coil ground, both good. 7. Checked flywheel key, good. 8. Checked for intake leak by spraying carb cleaner around all mating surfaces, with no change in running. Not sure what to do next, any help appreciated.
Backfire and popping sounds like lean running. You might run engine with some choke and see what happens. Bad cyl temp increase while good cyl decreases?Honestly I wouldn't lose sleep over it. On a typical v-8 for example, every cylinder will not have the same air fuel ratio and temp as well. Many a factor causing this. Cylinder head torque and sealing condition. Valves and so on. Could be down to one coil firing hotter or a weak coil for example.
Where are you measuring exhaust temp? Normally measured near cylinder. Normal would be small hole about 3" from cylinder with thermalcouple probe about near 1200°F. But if on outside tubing little less. Heads less than 400° F (200 maybe idle). What adjustments on carburetor, maybe only 1 idle mixture and fixed high speed jets? Carb dies have a port for each cylinder. Replace carb base gasket?Trying to help my neighbor. John Deere L120A B&S 20hp twin,406777 0139 E1. Has some popping and loss of power. Checked with infra red thermometer and the right side exhaust is about 100 degrees cooler than the left. 1. swapped plugs, no change. 2. checked compression, both around 140. 3. Checked valve lash on both, all set correctly. 4. Checked valve travel, both exhausts were same and both intakes were the same. 5. Will run on each cylinder by itself. 6. Checked diodes in coil ground, both good. 7. Checked flywheel key, good. 8. Checked for intake leak by spraying carb cleaner around all mating surfaces, with no change in running. Not sure what to do next, any help appreciated.
Forgot to mention guy said it was running fine til he ran out of gas. When it started to run bad he replaced fuel filter and fuel pump. Maybe dirty carb?
