B&S single cylinder 14hp OHV valve problem.
lbrac
Could it be a failed cam-mounted decompression mechanism that is used on some B&S engines? Symptoms sound similar to engines with this common problem.
Mrsmit
Thanks. Already fixed. Read thread.
Briggs 14hp OHV would a 280000 series . IN 003-005 EX .005-.007 Jam Nut or set screw 45 lb-in. (5 Nm)
Reported this garbage as Spam
