B&S on a DC silver eagle wiring & misc help
Preston1977
You
Hope you survived the storm.
The grey should go battery voltage with the ignition turned on
If so it goes the solenoid on the carburettor .
The black should be open circuit to ground with the ignition turned on & ground when the ignition is turned off and if that is the case it goes to the magneto .
The red will be battery voltage and goes to the rectifier
You were spot on dude, very much appreciate the help! Now I just have to figure out the pulley and belt lay out.
Preston1977
They should be exactly the same
They pulleys weren’t attached when I picked up the DC. I’m pretty certain I have it figured out I’m just waiting on the springs for the 2 tension pulleys to get here
