Boobala
- Feb 15, 2015
- 7,000
WELL, I've had my head up my arse, AGAIN, looking through the parts manual of the ( 44 R 877 ) & ( 44 N 877 ) engines I OVER-LOOKED the difference in carburetors and intake manifolds, what a DIFFERENCE !! it appears the 44 R uses a "2 barrel" carb & intake manifold, whereas the 44 N uses a BIG "single barrel" carb & intake manifold, hence the difference in linkages & controls, ( also the 44 N diagram shows the bracket for using a MANUAL choke ) although I don't think that engine uses one because it seems to be the THERMOSTAT controlled "EASY-START engine that our member ( motoman ) has, The carb on the 44 N looks like the exact same NIKKI carb I have on my 17.5 HP Briggs single cyl., maybe just a BIGGER model ..??? this is the first time I've noticed a 1 barrel carb on a twin cyl. engine ..STRANGE ?? Well here's a few more diagrams to ponder, ........ (upper right corners on some diagrams elude to model #)
AND back to the manuals, WHAT ELSE have I missed ??..:laughing:..:laughing:
