B&S Hard Starting
Firebird2
I have a toro 20039 personal pace rough running and a whooping sound, I found the flywheel key sheared(fixed), A hole in the head gasket (fixed), cleaned carb, starts but stalls and is hard starting very frustrating, come to find out the wrong primer bulb was replaced with a solid bulb and not the correct one with a hole in it p/n 694395 used on non adjustable carbs, it now starts on the first pull ?
BlazNT
Did you notice this post was from 2012?
Hey , give him some slack.
A new member who is actually reading the old old threads rather than just posting a common problem that has 300 repair threads already posted.
BlazNT
Well, I guess it is unanimous. I'm being an arse. To time out I go.
