Actually, today I have a question about a Briggs and Stratton gas powered pressure washer that I bought at Lowes. It is fairly new and has no adjustments or primer bulb. It just has a slide lever for run or stop.
When completely cold, it starts and runs fine. I use fresh gas. But, if I shut it off to refuel, it will not restart, or even fire. But, the next day it WILL start and run fine. I took it to a mower repair shop and the mechanic checked it the following day, so, of course it ran ok. He could find nothing wrong with it.
But, why does it not start again, after running for an hour or so? Once I tried to restart it, after it was stopped for an hour, and it started ok, but now it won't even do that.
Now I see why some guys call the B&S engines, Breaks and Scrap'em.
