jono252525
- Sep 7, 2017
- Threads
- 10
- 61
I am rebuilding a B&S engine model 256417-1134-E2 code 9711193A on a John deer Generator model 550GE 5500 Watts .
I need to know is, how do I make the timing with the 2 counter balances gears located in the Crankcase cover ? There is no timing mark on the balance gears but there is like a rivet on each one of them, that I could use as a timing reference maybe. The Crank Shaft as usual as the timing mark that I time with the timing mark of the Cam Gear.
If someone as the work shop manual ,I would appreciate.
Thank you.
Thank you.
