- Nov 29, 2014
- 24,995
The rings take a beating from the burning fuelHello,
Why should the carbon ring around the bore be left? Is it to prevent any lip from damaging the rings at TDC?
Thanks.
The lip of carbon around the top of the bore goes a long way to alleviating the pressure & heat that is almost instantly applied to the rings .
So unless you are removing the piston you leave the carbon ring alone
Professional mechanics use a tool called a Ridge Reamer to clean the carbon ring off when removing pistons and it is just about the most expensive tool I have particularly when you consider it gets used once or twice a year at best .
The absence of the carbon ring was one of the big problems to overcome when developeing hydrogen powered engines because there is no carbon build up to protect the top ring so that required a total redesign of the piston rings and some engines now use 4 rings & / or a double thickness and deeper radial depth top ring .
