B&S carb
Geochurchi
Hi All, I pulled the fuel supply line off this carb, and found this substance in the port, it can’t possible be normal, engine did run quite will, I removed the top of the carb and everything looked ok , this substance blew out with compressed air, lower port is connection for PVC tube.
Any thoughts?
Cheese omelet?
Definitely flush the carb, tank and lines.
Actually that looks like corrosion/sludge from running E-10 gas.
Geochurchi
it’s a Nikki carb, anyone know the correct rebuild kit, numbers on the carb.
22 122 23R. 808883. 6100
Thanks
Thanks
Do an engine model lookup then check on your carb parts for carb kit.
