Geochurchi
- Aug 16, 2021
- 23
- 69
Hi All, I pulled the fuel supply line off this carb, and found this substance in the port, it can’t possible be normal, engine did run quite will, I removed the top of the carb and everything looked ok , this substance blew out with compressed air, lower port is connection for PVC tube.
Any thoughts?
Any thoughts?
