The engine is a 28N707. It ran (probably) for about an hour with a lot of gas mixed in the oil (due to defective carb needle). Could this already be enough to damage the piston rings to a degree that oil gets combusted in rough quantities afterwards?
I know this looks like the obvious cause. But before I change the piston rings I would like to know if these symptoms concur with it:
- at low rpm it smokes a lot more than at high rpm
- high load smokes a lot more that no load
- at the highest mark on the oil level rod, it burns a lot more oil then on the lowest mark
Especially the last point doesn't make any sense to me, how can this be explained? Does the cylinder wall gets so much less lubrication if the oil level is lower? The compression still seems good and I didn't recognize any loss of power. Could it also be the head gasket or maybe something with the crankcase breather? Because with all this gas in the oil, the level was way too high and it also blew a lot of it out of the breather tube. Maybe the breather valve or breather filter is clogged? The air filter is already replaced with a brand new one.
I just want to prevent to disassemble the whole engine and then realize it didn't fix the problem. Could there be another cause that I am overlooking or do these symptoms completely concur with raddled rings?
